Aluminium oxide chromatography problem
Posted: Fri Nov 21, 2008 6:55 am
Hi all,
I have been using aluminium oxide (alumina) chromatography to separate/purify components from a plant extract for a few years with reasonable success. The alumina is active basic (Brockmann activity I).
Recently the chromatography has resulted in the compound of interest (CoI) to elute with the more polar compunds in the extract as if it wasn't binding to the alumina at all. In the past the CoI would bind to the alumina and elute after the polar impurities had eluted.
The mobile phase begins with a 50:50 mixture of acetone and heptane, and the acetone is ramped up slowly to 100%. This has not changed. One clue is that I am getting a red band on a silica TLC plate (I spot each fraction on a TLC plate to identify the CoI after chromatography) with low Rf that I believe to be chlorophyll on the separations that fail. These red bands appear in similar fractions to the CoI.
Is it possible that chlorophyll deactivates or binds strongly to the alumina, thereby preventing adsorption of the CoI?
Any help would be appreciated.
mlh_pep.
mlh_pep.
