Chromeleon 7 script editing commands - abort LC-MS run
Posted: Mon May 06, 2019 6:05 pm
I'm using a Thermo Dionex 3000 LC system with chromeleon 7 software connected to a mass spec and was wondering if anyone with experience with this software can help. I'm using organic solvents (MeOH/water) and would like to avoid flooding the spray chamber of my mass spec and turning the plasma off, so I'm trying to figure out how to have the LC abort run if the plasma is off.
At this point I know that "Sampler.Relay_2" is the signal for my mass spec, and I can have it manually on and off by writing command lines like "Sampler.Relay_2.State=Off" in the script editor, but I'd like to say something like "if Sampler.Relay_2.State=Off, abort run". Does anyone have experience with this, or is it even possible to write commands like "if" in Chromeleon 7?
