Waters 2695 / Agilent 1100 max column temperature
Posted: Fri Apr 26, 2019 6:06 pm
Hi everyone,
We are looking to buy an HPLC system to run some carbohydrate analyses, and the protocol calls for a column temperature of 85°C. I have seen several papers saying they have used this protocol and temperature using a Waters 2695 or Agilent 1100 system, however the manufacturers' specifications indicate temperatures up to 60°C and 80°C, respectively.
Is there any known way to get the column compartments to heat up higher than the manufacturer's specification?
Thank you for your help!
Corentin @ C16 Bio
Corentin @ C16 Bio
