Split LC flow to ESI-MS
Posted: Thu Oct 28, 2004 2:18 pm
Hi everybody!
Does anyone know which is the best way to split HPLC flow to ESI-MS? We work with typical flows in HPLC (around 1 mL/min for 4.6 mm columns) and split this flow with a tee to put into de ESI interface around 50 uL/min. But we usually have problems of reproducibility that we adress to the splitting. I've seen that LC Packings offers a splitter that seems to be good, but it costs around 3000 euros
Which could be the best way to solve this problem, apart of using thinner columns or nano-micro HPLC?
Thank you very much.
