MSDChemstation causing pre_post.tmp file to not delete
Posted: Wed Apr 24, 2019 2:26 pm
by James_Ball
We are using MSDChemstation E.02.01 and have began to encounter a problem where when you use QEdit to review a sample, it will lock the permission of the file and not allow deletion which then prevents the pre_post info from being copied into that temp file on any further attempts to open QEdit. It also locks the permission so that you can not delete the file unless you reboot the computer and if you try to copy that sample directory to another computer over the network it will give the error that the host computer's administrator has not given you permission to access that file and also you can not use QEdit from another computer across the network with that sample. It does not lock every file, it seems more random, but it affects a lot of the files in the data directory.
Has anyone seen this happen before and know of a solution or cause?
