Detector outlet connected to pump overflow
Posted: Wed Nov 12, 2008 9:58 am
I found out (nearly the hard way) that my detector outlet had been put back into the pump overflow tubing. I did not see this for 2 days after return and the pump drain had nearly reached its limit. Luckily it hadn't overflowed into the pump or benchtop. This happened when I was off for 2 days. No-one has admitted to knocking the outlet loose from its drain tube and the re-connecting incorrectly. I have the reverse problem to CPG in that I have lower than BSc to train up too. I don't think its a good situation.
WK
WK
