Perkin Elmer Series 200 Flexar UV Detector
Posted: Tue Apr 02, 2019 10:49 pm
What does the flashing red check mark on the UV detector indicate? Would it be the monochrometer, power supply going bad, or other problem? I changed the Deuterium lamp and solvent to HPLC grade water. The check mark stills flashes red.
Update: “A/Z/ OUT OF RANGE” error is displayed, but THF and HPLC grade water result in the same error.
Any advice will be greatly appreciated.
