Antibody analysis with size exclusion
Posted: Wed Nov 05, 2008 8:29 pm
by chromochat
I am working with an antibody. It seems like that the antibody is not stable in the mobile phase (diluent) during the size exclusion analysis (autosampler temp: 2-8C). Mobile phase is a 10 mM Sodium Phosphate, 700 mMSodium Chloride, pH 6.1 ± 0.1.
I am not able to run more than 12 injections of the antibody between system suitability injections. Any suggestions on how I can improve the stability of the antibody in the mobile phase so that i can run more samples in one sample set?
Posted: Wed Nov 05, 2008 9:10 pm
by danko
How does this instability manifest itself? Please describe what you’re seeing.
Re: Antibody analysis with size exclusion
Posted: Wed Nov 05, 2008 9:32 pm
by chromochat
There is a decline in aggregate level within a run(same day). It looks like sample degrades over a 15 hrs period.
Posted: Wed Nov 05, 2008 10:08 pm
by danko
It seams to me that you’re “problemâ€
Posted: Wed Nov 05, 2008 10:16 pm
by chromochat
Thanks danko. I will play with the pH and salt concentration.
Posted: Thu Nov 06, 2008 3:24 am
by Uwe Neue
Well, the question is: what is an aggregate? If the aggregation is reversible within the time frame of a day, it is not a permanent aggregate. The people in your formulation department might be interested in your findings. Maybe a change in formulation could prevent aggregation?
Posted: Sun Nov 09, 2008 9:36 am
by HW Mueller
Is this an IgG? I have worked with several commercially available Mab of this type and have never seen a problem with aggregation. From this I assumed that handling these is well established for analysis and for the purpose of their use.
Could it be that your “aggregationâ€
