NIST11 compound search ?
Posted: Mon Mar 18, 2019 5:56 pm
by Chemiger
I am using a 5973 MSD that has a NIST11 database installed. I was wondering if I could carry out a search on the NIST11 database to see if it has a specific compound in it before I carry out sample analysis. as far as I can tell the Nist11 database is only available in the Agilent compatible format.
I am using MSD Chemstation vs E.02.02.1431
Chemiger
Re: NIST11 compound search ?
Posted: Mon Mar 18, 2019 11:07 pm
by Henrylozano
Chemiger
Hello If you want, you can send me your Chromatogram and I can do the analysis with AMDIS and others libraries.
Send me email to
henry_lp04@hotmail.com
Posted: Tue Mar 19, 2019 1:34 am
by soccerdad007
Hi Chemiger,
It has been a while since I used MSD Chemstation as we moved to MassHunter but the versions of MSD Chemstation I used had a feature in the data analysis called parametric retrieval which allowed you to search through the Agilent libraries for user specified compounds. You could even search based on CAS number.
Take a look to see if the feature is still there.
I found a previous post in this forum about this which could help
https://www.chromforum.org/posting.php? ... =4&t=31381
Kevin.
Posted: Tue Mar 19, 2019 9:07 am
by Chemiger
Chemiger
Send me email to
Thank you for the offer Henry. I will have to pass on this due to confidentiality reasons.
Chemiger
Posted: Tue Mar 19, 2019 9:08 am
by Chemiger
Hi Chemiger,
Kevin.
Hi Kevin,
Thanks for the advice I will look at that today.
Chemiger
Posted: Tue Mar 19, 2019 1:20 pm
by Consumer Products Guy
We used parametric retrieval a fair amount.
