Use of THF for gradient Methods
Posted: Thu Oct 30, 2008 5:26 pm
Iam currently involved in developement of a gradient method for analysis of a drug substance . I found that varying the organic solvent (M.phase B) from 100% Methanol to 4:1 (Methanol:THF) gives good change in selectivity with appreciable seperation for critical pair of peaks, but i observed that in the blank injected using this chromatographic condition there is appreciable drift (upwards) as the organic concentration increases during the gradient and the working Wavelength is above 260nm. My question is whether THF can be used in gradient elution and whether this upward drift observed can be minimised (or Absorbance due to THF can be matched) by addition of any additive to M.phase A.
Thank You,
Santosh Gandhi.
Thank You,
Santosh Gandhi.
