we use Agilent GC 6890 with SupelQ column for environmental (~300-350ppb) N2O ( split inj/oven/ECD - 150/35/320 oC, carrier He, make up P5), and it works fine with calibration N2O gas that has no CO2. When it comes to the real atmospheric air samples though, CO2 concentration is about three orders of magnitude higher and its peak comes out right before N2O, so N2O peak is totally lost. I know that for the systems with the packed columns CO2 trap pre-column or back-flash column could be used. I could no find anything like this for the capillary ones in the literature though. Help please!
