report setup in chemstation
Posted: Tue Oct 28, 2008 6:28 pm
by cooky
Is there an easy way to set up an extended report to show plate count? I currently have a report method in short form that I need to convert to extended so I can include a plate count column. Where can I get help setting this up?
Posted: Tue Oct 28, 2008 7:11 pm
by cbowen
If you change the report style from short to extended it will include the plate count. Just make sure your components are identified.
Re: report setup in chemstation
Posted: Tue Oct 28, 2008 7:26 pm
by zokitano
Yes there is. In Data Analysis go to the menu bar "Report", choose the "Specify Report" from the fall-down menu, and then in the "Specify Report" window, choose "Performance" for "Report Style".
Best regards
