Varian Galaxie/ProStar HPLC Injection Problem
Posted: Mon Oct 27, 2008 9:04 am
I'm attempting to run a semi-prep affinity separation to extract an enzyme from blood plasma using a self packed low/medium pressure glass column. We recently bought a prep LC kit to allow us to do this work on an existing HPLC system from Varian, running Star, to save on bench space. This had been going OK until recently. The problem is that the kit I'm using doesn't want to inject the entire contents of a sequence list. Typically I'll get all but the last injection through, but now it's started to give up after the first 2 or 3. Also the system can take several attempts at starting a sequence, although at other times it starts first time
The stand alone (i.e. not networked to an intranet etc...) system I'm using consists of a Model 410 autosampler with prep option installed (Varian badged, but made by Spark Holland), ProStar 240 Ternary LC pump (Varian), 325 UV detector (Varian) and a Model 701 fraction collector. The CDS is Galaxie v. 1.9.301.220, also from Varian.
I've read a comprehensive debate about the merits (or not) of Galaxie on this forum but no one mentioned a problem such as this. Things were going quite well with Star, but that wouldn't control the fraction collector so Galaxie was installed to allow that functionality.
Does anyone have any thoughts or suggestions? The engineer has been called but won't be available until mid-november. Through talking to Varian they seem to have an issue with the PC used, which formerly ran the system when it was running Star. However, the spec is fine according to their own (Varian's) literature.
Dan.
Dan.
