Cryogenic colling for Agilent 6890 GC
Posted: Tue Oct 26, 2004 6:30 pm
I am using an Agilent 6890 GC (with MSD) to analyse for BTEX and other volatile hydrocarbons in groundwater using SPME extraction. To attain an initial oven temperature of 30 degC we are using liquid CO2 for cooling. The ambient temperature setting (in ChemStation software) is set to 25 degC, Quick Cooling is set OFF, Timeout Detection is ON and Fault Detection is ON. Ambient room temperature in the lab is about 25-28 degC, but sometimes reaches 30 degC. The system has worked well but we go through a standard size cylinder of LCO2 (50 lb of CO2) in about 20 analyses. Is this to be expected? I had hoped that the cylinder would last longer. Any comments and suggestions most welcome.
Thanks.
Andrew
Thanks.
Andrew
