EZChrom - Advanced Report
Posted: Mon Oct 20, 2008 5:26 pm
by fstabile
I don't know if there are advanced users on that subject, but here goes:
We are changing to Agilent's EZChrom Elite. At the same time we are trying to reduce paper trail.
Playing around (more than just playing actualy, and more than around), I've found a few ways to show results in a neat, almost universal, report.
In a guide, we had a 'Content Uniformity Report' shown to us, that gets informations from the method. In the same guide, there is no info on the instruction (such as =Data.Area...) to get method infos.
So how is it possible? Is there a more extensive list?
Thank you in advance
Posted: Tue Oct 21, 2008 2:52 am
by jllindahl
On the EZChrom Elite CD is a document "Advanced Reports.pdf" that details all the available functions you can include in the report.
Best Regards,
John Lindahl
Quality Manager
Agilent Technologies, Inc.
Posted: Tue Oct 21, 2008 11:25 am
by fstabile
Thanks for the info. It is greatly appreciated.
It seems you cannot access the information in a method. I was looking for a way to 'extract' the values for the calibration curve such as the values of Levels of Standards, RSD of a level and r2 of the curve.
Or is it a fonction implemented, but not documented?
Posted: Tue Oct 21, 2008 3:40 pm
by jllindahl
I don't believe those functions are directly available from the advanced reports. There may be another possibility if you can do a bit of programming with one of the EZChrom Elite automation interfaces.
Best Regards,
John Lindahl
Quality Manager
Ezchrom elite
Posted: Wed Oct 22, 2008 7:23 am
by chandusabini
Dear Agilent experts,
Can get make report showing the all chromatagrams with results(Area/assymetry/RT/%area) of slected multiple chromataograms. If so please show me the chromatogram and how i can make, please let me knwo.
regards
chandra
Posted: Wed Oct 22, 2008 11:22 am
by fstabile
It depends, on several 'sheets' or on one?
For several, you just need to create a custom method report that would include the information. When you process the sequence, you'll have each datafile printed out. In our lab, we use the 'Run Report' table.
If you want all your chromatograms info in one report. You can get almost everything with the advanced report. But I have'nt found out anything to report multiple chromatograms.
Re: Ezchrom elite
Posted: Thu Oct 30, 2008 7:48 am
by jwmol
regards
chandra
You cannot display or print chromatograms in "Advanced Report". It takes quite a bit of programming to do it in a normal Method Report. And even then only after analyzing the last sample, the Method Report will be complete.
Example:
Cheers,
JW
