new to HPLC have some questions :)
Posted: Fri Oct 17, 2008 5:41 pm
by che313
Dear all HPLC expert and user
I'm looking for utilizing liquid chromatography in our lab where our duty is for identifying drugs (tablets, powders, samples, etc..), detect drugs in body fluids; blood & urine.
My questions are:
* How can I build a HPLC system which satisfy my requireds. (i.e. best injector, type of pump, type of columns, best detector, etc...)
* Which books I have to read as a biggner?
* Which websites give me a better understanding for HPLC?
Best regards
Posted: Fri Oct 17, 2008 7:41 pm
by skunked_once
You need to identify your requirements. What are your analytes, types of samples, numbers of samples, etc. As far as which brand of instrument, which vendors serve your geographical area? Can you attend some meetings where you can talk to other chromatographers doing similar types of analyses? You need to find out all you can from vendors and the literature.
Check out the sponsors of this web site. There is more than enough information to learn from. Good luck!
Posted: Fri Oct 17, 2008 7:42 pm
by Bruce Hamilton
I would suggest that you locate a suitable HPLC training course, perhaps even some of the on-line ones offered at this site.
If you plan on analysing pharmaceuticals and metabolites, you really need to be discussing the best options with instrument manufacturers, as you may need software and systems that match regulatory compliance requirements.
The critical aspect would be the local technical support for the instruments. There's no point in purchasing an instrument if you can't obtain good local support, so you need to find out what other local HPLC users recommend as well-supported products..
Also, all of the major brands ( Agilent, Waters, Dionex etc ) offer support and training, so maybe you should ensure they include some relevant training cources as part of any hardware purchase.
Bruce Hamilton
Posted: Sat Oct 18, 2008 10:01 am
by tom jupille
DAD/signals
Posted: Mon Dec 15, 2008 12:53 pm
by Ninocka
Well, if there is someone who could answer me this:
when I have to set the wave length, there is
store signal, Bw Reference, Bw
what does this Bw, and Reference mean?
Most tnx in advance...
Re: DAD/signals
Posted: Mon Dec 15, 2008 1:36 pm
by JGK
Which instrument? Terminology will differ with each manufacturer
Have you read the User manual?
Posted: Mon Dec 15, 2008 1:53 pm
by Ninocka
read it on the help menu, and there is no explanation, just an example...in ChemStation tutorial.
I use Agilent HPLC now.
Posted: Mon Dec 15, 2008 3:23 pm
by danko
It stands for band width and the unit is typically nm. Sometimes it could be percentage.
P.S. Btw, your question is a bit off topic.
Posted: Tue Dec 16, 2008 8:25 am
by Ninocka
topic is:
so where else to put the question?
But, in the box "signal, Bw" I will put the length of interest, and what to put in the box "Reference, Bw". I could even turn it off, but I'd like to know for what it stands for?
In your answer was no explanation.
Tnx for trying...
Maybe you did not understand my question?
Posted: Tue Dec 16, 2008 10:14 am
by danko
Hi Ninocka,
topic is: new to HPLC have some questions
In this case, it would have been most appropriate to initiate a new thread/topic. The topic name might have been; “detector wavelength setupâ€
Posted: Tue Dec 16, 2008 10:40 am
by Ninocka
That is the answer i was looking for, because i saw that many methods have Reference wavelength to 360 nm and its Band Width to 100 nm, but did not know why. How they get that numbers.
Tnx for clarification.
N.
