Choosing the right column, mobile phase for peptide purifica
Posted: Wed Oct 15, 2008 1:35 am
I have a couple projects that require me to purify a peptide from insect brains. I have already successfully purified one peptide. I used 6 HPLC steps, exclusively reverse phase (C4, C18, C8, polymer, cyano) to purify the ligand to homogeneity. I frankly feel I got "lucky" with this isolation. I (arbitrarily) picked columns and mobile phase, and had good success moving the active fraction away from impurities.
It seems the choice of column, mobile phase, gradient is so arbitrary (i.e., you don't know how effective a particular system will be until you try it). Is that the case, or is there some logic in deciding which columns, mobile phase to try next?
Also, besides increased signal, what is the advantage of moving from larger to smaller ID columns for later steps?
