Sequence line msd chemstation
Posted: Tue Feb 12, 2019 4:35 pm
				Hi.
I’m trying to get the sequence line number to print on our reports. I’ve used Val$(_seqline) but it doesn’t work. It says the variable is not defined.
Any help appreciated.
Or would there be an easy method to print the sequence table automatically after certain individuals run their samples? While sequence is running.
