Waters Alliance 2790 no peaks?!
Posted: Tue Sep 30, 2008 3:06 pm
Using an Alliance 2790 in conjunction with a Waters LCT Mass spectrometer.
The syringe seems fine, sample is being withdrawn from the vials. Mobile phase is present, and reaching the MS ok. I've bypassed the column completely so it isn't a column issue, and I can't find any leaks. However I get completely flat chromatagrams containing only chemical noise from the MP.
The MS part seems fine, however I'm not seeing any sample peaks. I've checked the needle and the injection port. Both seem unblocked and correct. I'll try the injection valve tomorrow. Any other possibilities?
Thanks for any suggestions.
