An evaporation-proof 96-well plate system for GC?
Posted: Mon Sep 29, 2008 2:29 pm
I am moving from vials to 96-well plate format for GCMS assays. This is not really high-throughput, but for the convenience (i.e. speed and accuracy) of transferring samples from a 96-well extraction format to a matching plate rather than into individual glass vials. GCMS runtimes are about 30 min so this means 96 samples in 48h. The sample matrix is chloroform, so I am looking for minimal evaporation in 48h on the autosampler (CTC, no cooler, just at RT = 20 degreesC), and also minimal extractables.
What I have tested to date are pp plates with either heat-sealing mats or press-on pp caps. The heat-sealing mats have a terrible extractable profile, whereas the press-on pp caps have a cleaner profile similar to glass vials (with our usual PTFE-silicone-PTFE crimp-caps). However, there is an unacceptable evaporative loss from both - the press-ons lose everything (100 microlitres sample) in a few hours and the heat-sealed mats in 24-48 hours. Our std crimp-sealed glass vials don't lose anything for weeks at RT.
Can anyone offer advice on the best sealing mat/plate combination solution for this setup? I know there are PTFE-faced silicone mats on the market that will probably give a cleaner extractable profile, but their ability to minimize evaporation of an organic solvent like chloroform is an unknown. I don't want to go down the route of microvials with crimp-caps in a 96-plate format, as the time taken to prep and seal such a format defeats the object of moving away from standard vials.
thanks
Tony
thanks
Tony
