Page 1 of 2
Is it possible to calculate CU (Acceptance Value) in Empower
Posted: Sat Sep 27, 2008 10:28 pm
by laloo
does any one know how to set up formula to calculate Content Uniformity (Acceptance Value L1) in Empower 2?
Please provide the formula if any one know how to set it up in Empower 2
Thanks!!
Acceptance Values Calculations in Empower
Posted: Thu Jun 11, 2009 8:27 pm
by msolorza
Hey Laloo!
I have the exact same question as you do.
To do this, you will have to develop some custom fields to handle the data generated by Empower during an analysis.
The thing is that AV calcs are common in the industry and I am wondering if this has been done already. I am fairly sure that it has been done. I would simply like to find this custom field(s).
I saw that you posted about a year ago. Have you made any progress on this issue???????
I'd be happy to hear from you either way. Regards
Posted: Fri Jun 26, 2009 8:46 pm
by shahis77
u can do that using excel sheet..........why to creat a custom field in empower for such a simple calculation..
Content Uniformity Calculations (Acceptance Value)
Posted: Tue Jul 28, 2009 2:21 pm
by cdsman1001
It is possible to do it in Empower 1154 and of course in Empower 2. I have created custom fields to determine which case (6 situations) and based on that it calculates the Acceptance Value. Furthmore, it gives a Pass for AV<=15 or Fail for AV>15
Posted: Tue Jul 28, 2009 6:16 pm
by cdsman1001
When you can do something by Empower, it's better to do it by Empower because Empower is a secure and a validated system.
Custom Field for acceptance value
Posted: Fri Apr 09, 2010 1:55 pm
by EmpowerGuru
Here is what the custom field for acceptance value. This is a good way to do it because it requires nothing for the analyst to setup in the sample set.
EQ(GZ_Selection,10)*(GT((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,10))/10)
,101.5)*(((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,10))/10)-101.5)+2.4*
CU_STD_DEV)+LT((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,10))/10),98.5)
*((98.5-(%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,10))/10))+2.4*CU_STD_DEV)+
RANGE((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,10))/10),98.5,101.5)*2.4*
CU_STD_DEV)+EQ(GZ_Selection,11)*(GT((%.%.%.SUM(GZ_Content_U*
EQ(GZ_Selection,11))/10),101.5)*(((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,11))
/10)-101.5)+2.4*CU_STD_DEV)+LT((%.%.%.SUM(GZ_Content_U*
EQ(GZ_Selection,11))/10),98.5)*((98.5-(%.%.%.SUM(GZ_Content_U*
EQ(GZ_Selection,11))/10))+2.4*CU_STD_DEV)
+RANGE((%.%.%.SUM(GZ_Content_U*
EQ(GZ_Selection,11))/10),98.5,101.5)*2.4*CU_STD_DEV)+
EQ(GZ_Selection,12)*(GT((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,12))/10),101.5)
*(((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,12))/10)-101.5)+2.4*CU_STD_DEV)+
LT((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,12))/10),98.5)*((98.5-(%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,12))/10))+2.4*CU_STD_DEV)+
RANGE((%.%.%.SUM(GZ_Content_U*EQ(GZ_Selection,12))/10),98.5,101.5)
*2.4*CU_STD_DEV)
Posted: Mon Apr 12, 2010 7:36 pm
by DR
Note to self - try this one!
Thanks EmpowerGuru! (and welcome to the board)
Posted: Tue Apr 13, 2010 4:03 pm
by DR
GZ_Selection and GZ_Content_U correspond to what?
gz selection and content U
Posted: Thu Apr 15, 2010 7:38 pm
by EmpowerGuru
GZ_Selection is an enumerator that is used as a drop down selection in the sample set. use as position. its has three selection: cu group 1, cur group 2, and cu group 3.
Content U is the actual result for the individual sample
too many groups
Posted: Fri Apr 23, 2010 2:08 am
by vishious
Hey Guys
I am using a similar custom field but it works fine with one or maybe 2 lots but anything more than that it takes for ever to calcuate AV sometimes 4 hours
and sometimes it would crash... wud do it for 3 lots then half way thru 4 it stops
anyone else have that issue with this custom field?
So what we ended up doing is cutting the formula down to include only 3 lots at a time but thats not very efficient
Posted: Mon Aug 30, 2010 1:57 pm
by EmpowerGuru
I had to limit it to three lots or it would crash.
Sorry.
If you could convince the lab to manually enter the result into the sample set and if you adjusted the custom field to use that value, it may work for any number of lots.
Re: Is it possible to calculate CU (Acceptance Value) in Emp
Posted: Mon Jun 13, 2011 9:40 pm
by ama1001
I have created the Custom Fields and they do not crash regardless of the number of samples. However, I created multiple fields, for T Value, M Value, Number of Units, Upper and Lower Assay Values and a Multiplier. It doesn't take a long time to calculate it either. I will post it one day, after I take the credit at my company...someone may be watching
http://cdsman.com/CU1.JPG
Posted: Tue Jun 14, 2011 3:31 pm
by DR
Nice. I showed a printout of Empowerguru's solution to a Waters rep - he said it was a "system crasher". I look forward to seeing your solution.
PS - I think Waters has included a solution in Empower 3.
Posted: Tue Jul 12, 2011 3:08 pm
by EmpowerGuru
It doesn't crash. Several labs are using it everyday. I crammed most of it into one custom field so that the validation would be easier. I validate each custom field so it is faster with less fields for me.
Posted: Tue Apr 03, 2012 3:00 pm
by ama1001
My formula is kind of similar, but keep in mind that RANGE does not include the boundries so, instead of starting from 98.5 to 101.5, your range should be from 98.45 to 101.51
