Electrochemical detector testing
Posted: Thu Sep 25, 2008 8:56 am
by Lyser
I have a problem with my IC-3000 Dionex system and I want to test my EC detector.
How can I do this?
tx
Posted: Sat Sep 27, 2008 9:56 am
by tom jupille
Check with Dionex. They should be able to provide you with an appropriate "PQ" (Performance Qualification" procedure.
Testing the ED Detector in the ICS3000
Posted: Sat Sep 27, 2008 11:29 pm
by Chris Pohl
Lyser,
Tom's advice above is your best bet but could you comment on what you want aspect you would like to test? There are many possible aspects to characterize including: response factor of the detector, electrical continuity, reference electrode performance, chromatographic dispersion, grounding.
Chris
Posted: Mon Sep 29, 2008 8:30 am
by Lyser
That's right!
I want to test particularly the gold electrode performance, I'm practically sure that reference electrode is good because pH is ok.
I will see with dionex for standard procedure to do that...
Tanks
