Regenerating Normal Phase Columns
Posted: Tue Sep 23, 2008 1:06 am
OK here's a question. We have a "wacky" normal phase method which uses both a cyano column and a diol column in tandem. We injected some samples which contained trace amounts of water and the chromatography started to fall apart.
We rinsed with IPA but that didn't seem to help too much. Then we rinsed with our mobile phase B - which is 70/30 hexane/ethyl acetate. That seemed to work much better.
This surprised me. What is generally the best way to regenerate normal phase columns after they have come in contact with too much water.
Much Thanks in Advance
