Analytical Method..Help or suggestion needed.
Posted: Fri Sep 19, 2008 7:55 pm
This is my first Analytical method experiment.I have to develop a Method for the Analysis of Coumarin And its Major Metabolite 7-Hydroxycoumarin
and to icorporate an internal standard into the method.
Ok this is what I have:
1. Coumarin
2. 7-OHC (7-Hydroxycoumarin)
3. O-Coumaric acid ( possible Internal Standard)
4. 7-Amino-4-Methyl-coumarin (possible Internal Standard)
The HPLC system will use:
UV-Visible detector or Photodiode array detector.
Mobile phase (ACN,MeOH,Water)
C18 uBondapak coloumn
Pump(2.5ml/min)
Now,these are the things I know and dont know:
1.Methanol is more polar than water.I dont know how polar is ACN and how it relates to Water and MeOH.
So which is the best mobile phase I can use here?
2.Coumarin,7-OHC,O-Coumaric acid,7-Amino-4-Methyl-coumarin are all polar (to me at least)
How do you know,which is the most polar among this ,followed by the less polar one?I know the structures of each of this componds,from this how can I guess/calculate which is more polar than the rest?
3.Of the two Internal standards(O-Coumaric acid AND 7-Amino-4-Methyl-coumarin),the latter one is more structurally similar to Coumarin and 7-OHC than the latter.So
Which of these should I choose as the internal standard?What would happen(to the chromatogram) if I choose the wrong standard?
Any help will be appreciated,and if you have any external links that would help me in this,please do post it.
Thank you
1. Coumarin
Pump(2.5ml/min)
Thank you
