Help me on this situation GC/MS!
Posted: Wed Sep 17, 2008 6:57 am
Hi All,
You see. ON SIM or TIC, the abundance is never negative. So then, the software will cut off the negative part of the signal as you see on the above picture. This situation can lead to incorrect intergration of peak. I don't know why. I have already changed the threshold value, but it didn't work. Pls, give me an experience advice.
Thank a lot.
Thank a lot.
