Results signoff in Empower2
Posted: Wed Sep 17, 2008 2:36 am
by laloo
Does anyone in this group uses the electronic signoff in Empower?
Can you provide detail or any reference for electronic signoff in Empower.
I appriciate your help
Laloo
any one knowing about using signoff in empower?????
Posted: Sat Sep 27, 2008 10:26 pm
by laloo
Can any one knowing about using signoff in empower provide details?????
Posted: Sun Oct 12, 2008 9:35 pm
by danko
Hi Laloo,
If you bring your "Result Set" in "Preview" and go through all results, you’ll be able to sing off the previewed results, as soon as you’ve reached the last result/page.
In order to enable the sign off capability, you’ll need to edit the report method first. This is done by right-clicking on a randomly chosen blank location in the opened report then choosing properties and finally choosing “allow this report to be used for sign offâ€
