Ammonium Formate as mobile phase in LCMSMS
Posted: Sat Dec 01, 2018 1:43 pm
				I am trying out a new method called EPA 1694. I wanted to test for acetaminophen in water hence I had to prepare the buffer solution as mobile phase for the LCMSMS.
Ammonium formate is used as part of the buffer solution for mobile phase. Upon running a search on the internet, I found out there are many different kinds of ammonium formate, which includes ammonium formate specifically for mass spectrometry.
Hence I will like to enquire if am I able to use normal reagent grade ammonium formate for this test or must I use mass spectro specific ammonium formate?
Thanks in advance to anyone who have the answer to my question.
