Empower2 Intersample Custom Fields
Posted: Tue Sep 02, 2008 7:51 pm
by heebsh
Does anyone know how to create and view results of intersample custom fields in Empower2? As an example, I would like a custom field to calculate the % difference between the average areas of 6 injections of standard A and 6 injections of standard B.
I believe that I have set up the custom field according to instructions in the help menu, but I am not sure if it was done properly. I am also not sure how to display the value correctly in a report, so the problem may lie in the report.
Posted: Wed Sep 03, 2008 7:59 am
by aceto_81
Intersample custom fields are though, but possible.
Could you post what fields you have made and how they are setup, so its a bit easier to see what's going on?
Ace
Posted: Wed Sep 03, 2008 6:56 pm
by heebsh
After another analyst talked to a Waters rep the problem was solved. We needed to use % between the dots for injection and channel number in the custom field. The help topics had led us to believe that they were not necessary.
