headspace from PE
Posted: Thu Aug 28, 2008 1:58 pm
by che313
Any one have headspace system from perkin elmer?
I need help in creating a method and calibrating the components.
Posted: Thu Aug 28, 2008 3:52 pm
by zokitano
We have PE's Turbo Matrix 40 HS sampler.
What precisely you need to do? And what parameters you want to set up?
Posted: Fri Aug 29, 2008 6:05 am
by che313
thanks zokitano
It's not regarding the sampler, it is regarding thier software, totalchrom
I need help in creating a method for beverage analysis (ethanol %).
By the way in which application you are using headspace?
Posted: Fri Aug 29, 2008 9:33 am
by zokitano
Dear che313
In my lab I have PE Clarus 500 GC connected with TurboMatrix 40 HS. I am using the TotalChrom CDS but only to control the GC system not the HS.
All the HS parameters I set directly on the HS sampler (manually). When an injection from the HS occurs, HS sends a signal to GC to start the run. Everything that I can set and control with the TotalChrom software is related to the Clarus 500 GC. That's why I don't understand your problem with the HS (that is controlled by TotalChrom?)
What model of HS and GC do you use? What parameters you want to set up on your HS sampler or GC? Which part of the TotalChrom makes you troubles (method set-up, processing chromatograms, publishing the reports, etc)?
I mostly do residual solvent analyses in pharmaceutical preparations. Also I have done ethanol analyses in different matrices.
Give us more information so we could help you
Regards
Posted: Fri Aug 29, 2008 1:10 pm
by che313
thanks again zokitano
I have the same configuration as you, clarus 500 & turbo matrix 40 HS.
As I said before my problem is with the totalchrom not the headspace nor the GC.
I need help in setup method and calibrating it.
I want to do ethanol analysis in both blood and beverages.
Posted: Mon Sep 01, 2008 8:52 am
by zokitano
Dear Che313,
Sorry for the delay, but all the manuals I have regarding TotalChrom are at my workplace. Now I have them, so if you like I could send you, via e-mail, some useful pdf-s/manuals/tutorials how to work, optimize and set-up methods in TotalChrom software. There you'll find the answers for your questions.
Regards
Posted: Mon Sep 01, 2008 6:50 pm
by che313
Thanks Zokitano
I appreciate your help.
Kindly send them to
che313@hotmail.com
