Software for 8453 UV-vis chemstation
Posted: Tue Oct 30, 2018 7:14 pm
by alopes
Hi all,
I apologize ahead of time since this is not a chromatography question, but I thought this would be a good place to ask. We recently pulled an 8453 UV-vis spectrophotometer off of the shelf, and the computer we were running it on is dead. We have all of the product keys to run it, but I cannot find the hard copy of CDs anywhere. Does anyone happen to have version A.10.01 or B.01.01 that has G1115AA? The chromatography CDs do not seem to have that software revision on it. Agilent has been less than helpful...
Please let me know if you can help!
Thank you,
Aaron
Re: Software for 8453 UV-vis chemstation
Posted: Wed Oct 31, 2018 3:25 am
by gaumit
This product version already absolute by Agilent, but
I could help you got one, let me know if you need
Posted: Wed Oct 31, 2018 11:41 am
by alopes
Hi Gaumit,
I am out of options and any help you can provide would be highly valuable.
You can contact me at my personal email if you would like to discuss more:
aapon123321@gmail.com.
Thank you,
Aaron
Posted: Wed Oct 31, 2018 1:46 pm
by Consumer Products Guy
I think that G1115 software on the versions of Chemstations was only with the earlier revisions, like before A.9
Posted: Wed Oct 31, 2018 3:29 pm
by gaumit
For 8453 with Jet direct LAN card or G1369A LAN card, could be use max to B04.03 version,
but it up to Window version and IO version also.
Hi Aaron, I will drop email to you
Sincerely,
Posted: Thu Nov 01, 2018 9:28 pm
by alopes
My colleague was able to help me get it to work on a copy of B.04.03.
Thank you all for your help.
Best,
Aaron
Posted: Sat Dec 16, 2023 1:42 pm
by ndemarco
I'd definitely appreciate a later version. I access a 8453 via a JetDirect 400N, and run A.08.03 on a WinXP VM using remote desktop. I can't imagine what modern conveniences might be waiting for me.
Posted: Thu Jan 04, 2024 12:43 am
by nhe
I have also been looking for a newer version of software for HP8453. I have version A.06.04 which can only run on Win98, and my old PC is having problems starting.
Agilent refuses to help as they stopped all support one year ago - they say.
If you find a solution - please let also me know.
Best regards,
Niels
Posted: Thu Jan 04, 2024 2:16 pm
by KM-USA
Since you already have a Chemstation license and license number (which you'd still use), I can supply replacement media for you. Post your E-mail address here, and after I E-mail you, you can delete that from your post.
That said, I ask for a minimum charge if I need to mail a CD disc, and a little less if I can send to you through E-mail/Internet transfer.
I have Chemstations from A.06 to A.10; but I'm not a computer expert but according to what is included in the software, it seems to me that A.08 is the newest that supports 8453 UV-Vis, and I don't know offhand what versions of Windows has been tested as compatible with A.08, there's an Agilent compatibility chart on the Internet.
A.08:
"Date: July- 13 - 2000
This file contains the revision information for the Software Products
on this CD-ROM.
ChemStation for GC, LC, LC-MS, CE and A/D Revision - A.08.03 [847]
ChemStation for UV-Vis Revision - A.08.03 [71]
I/O Libraries Revision - H.01.02.00
Bootp Server Revision - 1.2
ChemAccess Revision - A.01.03 [411]
ChemStation Companion Revision - 0.1.73"
A.09:Date: 24 - September - 2002
"This file contains the revision information for the Software Products
on this CD-ROM.
ChemStation for GC, LC, LC-MS, CE, CE-MS and A/D Revision - A.09.03 24-Sept-2002
I/O Libraries Revision - J.02.00.01
Posted: Tue Jan 23, 2024 9:42 pm
by ndemarco
Per
this Agilent forum post, the most current version to support the 8453 is B.05.04[8]. The version is Win 10 compatible.
Posted: Tue Jan 23, 2024 9:46 pm
by ndemarco
Sincerely,
I found the same info. Please email me with what yo uneed to get the latest B04.03 version. Thanks!
nmdraleigh@gmail.com
Posted: Tue Jun 25, 2024 1:17 pm
by mventer
Per
Where I can I get this version. My computer broke and I need to reload everything. The computer still ran windows NT
