DB 225 column test mix
Posted: Fri Aug 22, 2008 6:30 am
Hi
I would like to rinse my DB 225 capillary column with solvents for regeneration and after rinsing test the effectivenses of the procedure. Unfortunately the column test mix is unavailable on agilent's website (permanently) and I was wondering if sombody mayby has a material safety sheet or other document where I could find concentration of compounds in the DB 225 test mixture. Regards
Kasia
Kasia
