Sorbic Acid in Wines
Posted: Fri Oct 26, 2018 5:40 pm
Hello
I analysed sorbic acid and benzoic acid in wines using HPLC.
Between those two peaks, appears another peak, but I don't know what analyte is this. Please, could someone help me?
Mobile phase:
70 % acetate amonium buffer (0,4 g/L) pH 4,5 (ajusted with acetic acid)
30 % acetonitrile
wave lenght = 254 nm
The samples are diluited 10 x.
column C18
Thank you!
Mobile phase:
30 % acetonitrile
column C18
Thank you!
