Overlaying Chromatograms with offset retention times.
Posted: Fri Oct 26, 2018 1:55 pm
Hello. I have an Agilent GC model 7890B. I was wondering if there is any way to overlay chromatograms with offset retention times. I cut the column and reinserted it into the injector and detector. After making sure everything was secure, I started the GC. When I did my first two injections. the retention times were overlaying perfectly. The next day, I notice the retention times are completely off. I am not sure if this means my column is too short to compensate for my sample eluting or I need to install a new column. Is there anything to help with overlaying offset retention times? I use Agilent OpenLab for data analysis.
