Where can I obtain the new reporting template to cover all the calculations required by EPA Method 533 (see attached). Per Agilent, this report can be generated automatically in MassHunter Quantitative Analysis software using the built-in PDF-based reporting method. The report includes, among other, calculations for: Ion ratio (quantifier/qualifier), EIS recovery, and Manual versus original integration. It didn’t come with my new 6475TQ. What would the report be called? I will contact Agilent next week but in the meantime if someone can share a copy of the template, I would greatly appreciate it.
