All peaks distortion on chromatogram. help please!
Posted: Thu Aug 14, 2008 8:21 am
I am using a Zorbax C8 250X4.6mm, 5µ column. My flow rate is 1 ml/min. Injection volume is 50µl. Mobile phase-Buffer Phosphate 0.05M/Acetonitrile.
All the peaks have a very good shape on a new column, after some period of usage, ALL the peaks start to be distorted (they have tailing, the height is considerably reduced and further peaks distortion and splitting can occur). This phenomenon repeated again and again as I change the column (4 columns are not good now). After I used the guard with the new (5-th) column, the phenomenon occur even faster! The phenomenon is irreversible-I washed the column with Acidic Water, Acetonitrile, Acidic Methanol-without any success.
What is the reason? It seems to be physical problem (symptom is show up on all the peaks in the chromatogram)… But may be it is chemical problem -I suspect about xanthan gum that inside the sample injected (we try all the filters, but xanthan gum pass all of them), may be it remains on the stationary phase of the column. Please help! I am despaired and don't know what to do…
