Empower 2 - Making Export filename specific to the Run ID
Posted: Tue Aug 12, 2008 1:50 pm
Hi all,
Firstly, many thanks on the response to other people's questions, I've found them very useful!
I am only just starting out using the Empower system, and so apologies if this question seems trivial, or stupid
I am exporting files using the Export Method. However, I want the name of the text file to be specific to the name of the specific run of data that it is exporting. For example, if the Run Id is RUN1, I would like RUN1 to appear in the name of the text file that is being exported.
I'm not sure if this is possible in Empower, I'm presuming it's not, but if it is it would be very helpful.
Hope someone can help, and thanks for your time!
