I have a Shimadzu Sil-20AC autosampler, the other day I received an error "ERR SLIP X", if I turn on the instrument, thes kept the error and it does not allow me to do something. According with manual this is a possible malfunction with Needle's X-axis (sideways) movement is incorrect and the recommendation is "Turn the power OFF and contact your Shimadzu representative". Then I ordered the "PART* CABLE FPC-Z ASSY WITH SENSORS" and I changed the part, the error after change the part it was cleared, but when the intrument make some movments on X-axis I recieved the same error again, I turn off the instrument and inmediatly I turn on and the error was cleared, but when the instrument meke some movment on x-axys I recived the error again.
