Page 1 of 2
SLS Content in Empty Capsule Shells
Posted: Thu Aug 07, 2008 3:34 am
by vikmurush
I need to analyze empty capsule shells for SLS content (sodium lauryl sulfate)qualitatively or quantitatively. Please suggest your ideas/methods.
Posted: Thu Aug 07, 2008 3:41 pm
by Consumer Products Guy
ASTM 3049-89 (reapproved 2003) mixed indicator titration.
SLS CONTENT
Posted: Fri Aug 08, 2008 2:41 pm
by vikmurush
Could you please give more information about this method. I appreciate if you can give specific details like how to perform etc.
Posted: Fri Aug 08, 2008 2:53 pm
It's in the ASTM, look it up, I'd guess it's copyrighted material.
Posted: Sat Aug 16, 2008 6:58 pm
by vikmurush
could you please provide further information? Are there any titration methods available?
Thanks in advance
sodium lauryl sulfate content
Posted: Wed Dec 24, 2008 6:59 pm
by vikmurush
Could any of the experts proivde links to the analysis of sodium lauryl sulfate content by LC or by any method?
I appreciate your help
Posted: Thu Dec 25, 2008 4:54 am
by Vlad Orlovsky
Here is application for alkylsulfonic acids, you will need more ACN in the mobile phase for your compound:
http://www.sielc.com/application_144.html
SLS content
Posted: Fri Dec 26, 2008 8:23 pm
by vikmurush
Thank you very much for the information Vlad Orlovsky. Do you think that ammonium acetate 10mM with acetonitrile gradient from 5% of acetonitrile to 50% would give you some hopeful data? I would definetely try this with primesep and are there any other methods by UV instead of ELSD for quantitating SLS content? I would guess the sulfates can not detect by UV?
Thanks for your help.
Posted: Sat Dec 27, 2008 2:10 am
by mohan_2008
ELSD detection is widely used for detecting excipients such as Tween 80,
PEG's and other non-chromophore containing entities.
I doubt if the lauryl sulfate has a chromophore in it, hence the ELSD application. But, that is only my thought.
Posted: Sat Dec 27, 2008 3:28 am
ASTM 3049-89 (reapproved 2003) is a mixed indicator titration procedure. Am I correct that in the four months from August until your recent post that you did not try that? As the Soup Nazi said on the Seinfeld show: "No more for you" !!!
Posted: Sat Dec 27, 2008 4:59 am
by Vlad Orlovsky
You don't need to start with 5% ACN, you can go from 25 to 60% for example and 10 mmol of ammonium acetate.
SLS has no UV activity, so you need ELSD, CAD, RI or MS
Posted: Sat Dec 27, 2008 11:20 pm
by vikmurush
May i know what is ASTM 3049-89? I would really appreciate if you could give me some specifics.
Posted: Sun Dec 28, 2008 12:08 am
ASTM is
American Society for Testing and Materials; this material is copyrighted, one needs to purchase. If you had gone this route, you might have completed this last August.
http://engineers.ihs.com/document/abstr ... AAAAAAAAAA
Posted: Sun Dec 28, 2008 12:18 am
by vikmurush
Thanks for all the information. I will definetely try the ASTM route and Primecep with ELSD. What primesep column would be a good start? Is it should be a primesep 500? or any primesep that i could use? I have some primesep columns but i need to check what kind they are. Please let me know thanks a lot for all of your help.
Posted: Sun Dec 28, 2008 7:14 am
by XL
How much SLS do your samples contain? Or what is the detection limit requirement? If the SLS concentration is too low, say below 10 ppm, then ELSD may not be sensitive enough to provide reliable quantitation.
