I am trying to setup headspace analysis. I was checking the macros of the default loaded methods and was changing some things. I didn't work out. So i changed everything back to default, but when i try to run it. It skips the heating of the syringe, agitator, and no matter what is always taking sample from the Vial 1. I tried eveything i dont know what to do. Can anybody help in this matter. I am using the PAL cycle composer program. Thank you very much in advance
-sohaib
