Wavelength gradient program
Posted: Thu Jul 31, 2008 2:06 pm
Hi all, i am a new analytical person to the forum. I am working on a method in which i am using wavelength prog as follows:
0-22 min:283nm,22.1-45 min-210nm,45.1min-283nm.( total run time50min) Reason being the 1st analyte(RT13min) is visible at 283nm and 2nd one(RT30.1min) at 210nm. If such methods are accepted by regulatory authorities. Kindly give suggestions. Thanks in advance
