Empower Shutdown
Posted: Thu Sep 06, 2018 6:34 am
Hi ,
How can you check if you have added/confirm a shutdown (or indeed correct shutdown) to a sample set that is running ?
Is the only option to 'Alter sample set , click Yes and then click run samples and add shutdown again ?
