Column Conditioning-Highly Important, help needed ASAP
Posted: Mon Jul 28, 2008 2:54 pm
Could you advise on best method to condition a column.
I am about to start using the new Amino Apex column, to detect tocopherols (vitamin E) in food oils.
Mobile phase is hexane: ethyl acetate 80:20, flow rate 1ml/min, please advice how I should begin as the specification sheet states that the shipping solvent is IPA?
What steps should I take before using the mobile phase? One method that I have been given uses methanol, followed by ethyl acetate then the mobile phase.
Is this the best way to condition the column??
