3-(1,2-Oxazolidone)
Posted: Mon Sep 03, 2018 7:50 am
by ilycip2015
Could you tell me more about oxazolidone hplc analysis?
Re: 3-(1,2-Oxazolidone)
Posted: Mon Sep 03, 2018 11:19 am
by mattmullaney
Hi ilycip2015,
Does the compound you are interested in have CAS number 497-25-6?
Posted: Mon Sep 03, 2018 12:16 pm
by ilycip2015
CAS Number 20073-50-1• 3-Oxazolidineethanol
Posted: Thu Sep 13, 2018 2:23 pm
by Vlad Orlovsky
The analysis can be done similar to this application:
https://helixchrom.com/compounds/ethanolamine/
You will need ELSD, CAD, RI or mass spec to monitor your compound. For ELSD/CAD you can replace ammonium formate buffer with TFA. Retention time is mostly controlled by amount of ions in the mobile phase. You are operating in weak RP and medium strength CE.
Contact me if you have questions.
