Problems with auto-login to forum.... I am
10 posts Page 1 of 1
Is anyone else having auto login problems. of course I ticking the check box.
It used to work fine up until about 2-3 months ago. Any ideas anyone?
I reinstalled windows at home, and had to add this website to my "trusted websites" category in security for internet explorer...then it started working well, again.
Not having any problems at all
Rob, no changes to the Forum software have been made for well over a year, so I can't identify anything at this end that could cause the problem.
About the only thing I can suggest is that you might try switching to a different browser (Firefox or IE7) and see if that has any effect.
It doesn´t work anymore here either, but this was after I started using two PC, one at work, the other at home.
For me it works from both computers (work and home). The only problems i had it was when I was trying to access from www.chromatographyforum.com instead of www.sepsci.com/chromforum, but it looks like this problem has been resoved...
Super, Kostas, sepsci.com.... has worked 3 times now!
OK, the www.sepsci.com/chromforum route also worked for me. Yes, I was having trouble before....who woul've thunk it???????
"www.chromforum.com" and "www.chromatographyforum.com" are "shortcuts" to "www.sepsci.com/chromforum". In principle, they should all work the same way. In practice, they do behave differently, but I'm not enough of a programmer to understand why!
YES !!! Still works now, from both locations using www.sepsci.com/chromforum. I'll need to save that information of my floppy disc.
