MassHunter: decimal places and chromatogram areas
Posted: Tue Aug 28, 2018 1:13 pm
by antonio_rosato
hi to all,
i'm wandering if it's possible to set the number of decimal places in area values of integrated peaks in TIC chromatograms. often, it happens that when I integrate manually peaks in chromatograms, the value of area has not decimal places.
thanks
Re: MassHunter: decimal places and chromatogram areas
Posted: Sat Sep 01, 2018 6:07 pm
by ATAlR
There is a xml file in c:\users\(user name)\AppData\roaming\Agilent_Technologies\ (the file is appsettings.xml or something similar). With notepad you can open this file and change number of digits after decimal point, but please do a backup of this file
Posted: Tue Sep 04, 2018 8:26 am
by antonio_rosato
Thank you very much for answering to my question. unfortunatelly, i can't find this file. probably, the path is not proper to my pc.
