Empower processing
Posted: Tue Aug 28, 2018 11:27 am
Hi ,
I am carrying out some development work and have alter sample set, stopped injection before end of run time , Aborted sample set , paused sample set at certain points etc
When I come to process the sample set not all injections are in the result set
Each injection is present in the sample set
I know its something to do with injections been disassociated with the sample set method
How do you process these ,, individually? then how do sign these off as one group
thanks
thanks
