UPDATE: Leaking Waters Seal Pak for 717 Autosampler
Posted: Wed Jul 23, 2008 2:26 pm
I know it's rather obsolete equipment but I like to update to maybe help others. The needle has to be manually adjusted to where the "flag" is at the upper portion of the indicators. Test for leak by manually injecting methanol until it stops. Replace the seal pak unit and then calibrate the seal pak according to directions. Thanks to Waters support for this one and for those who responded to my originally inquiry for their input. Cheers!!
