Multiple summary custom fields in one sample set?
Posted: Mon Aug 20, 2018 8:23 am
Is it possible to calculate multiple summary custom fields in the one sample set if I use different labels? Heres what I want: The sum of all amounts of 1 batch divided by a figure in CConst1: I label each batch the same and the formula is: Peak, Real, Calculated:
SAME.%..SUM(Amount)/CConst1.
I have 3 sets of batches (10 samples per batch) and I label all 10 samples of the 1st batch as A, the second batch as B and the third batch as C and I add summarize custom fields to the end of the sample set. But when I process the run and look at results im not getting the correct value at all, its either too high or too low and I don't even know where the figures are coming from. Does anyone know is it possible to do this calculation or am I missing something small..
