H2O2
Posted: Fri Jul 18, 2008 9:19 pm
I’m a student and I’m just starting to use gas chromatography. I have some questions and I would appreciate your help.
I'm working with Catalytic Peroxide Wet Oxidation and my samples have acetic acid and H2O2.
I want to measure the concentration of acetic without the interference of the H2O2, or measure both, separating the peaks.
I’m using gas chromatography, a ECONO-CAP capillary column, carbowax 19653 (polyethylene glycol), and the detector is a FID.
I want to now if the H2O2 can damage the column and if it’s possible to measure it with this method, this type of column and detector.
