Tailing of Polyol
Posted: Fri Jul 18, 2008 7:53 pm
Has anyone experienced this before? What suggestions do you have?
My goal:
Develop an assay for EGCG, a green tea compound. It is rich in hydroxyl groups (do a google images search for EGCG to see the structure).
My assay:
water/acetonitrile/0.04% formic acid mobile phase
Luna (or ACE or hypersil) C18 column
alliance/Quattro Micro HPLC/MS system
My problem:
Tailing (Tf ~ 2). I might expect from a basic compound but I did not expect to see it with this compound. Since I'm not sure why the compound is tailing so severely I'm not sure how to solve the problem. Luna is an ultrapure silica and it is end capped so I'm hesitant to think it is being caused by free silanol interactions.
What I've tried:
-I spent some time on the phone with the Phenomenex folks who are surprised by the excessive tailing.
-I have eliminated system problems as the cause. Other compounds on the system exhibit acceptable tailing (Tf ~ 1.2). The IS, also a hydroxide rich compound tails slightly less (Tf ~ 1.8).
What I am going to try:
-A more basic mobile phase
-Heating up the column (had been running at RT)
-Injecting the sample at a high aqueous mobile phase to pre-concentrate the sample at the head of the column.
After those three things, I'm out of ideas. As mentioned above, we see this tailing on a variety of columns (all silica based because those are readily available in the lab).
Any advice would be helpful. Thanks!!
My goal:
My assay:
My problem:
What I've tried:
